FEFI mode disabled for ports set in the 64 bit port Map. If there are any errors, error will be non zero and bit set will indicate that the corresponding port did not have FEFI disabled.
There is no remedy because there is no problem to be resolved.
Debug-Data
FEFI mode disabled in batch for port map %fefiPortMap% error %errorCode%
| Name | Type |
| fefiPortMap | xInt64 |
| errorCode | xInt64 |
